Author Topic: Storing values in Axon Microcontroller?  (Read 2788 times)
Offline Hasan999Topic starter
« on: January 02, 2010, 07:07:57 PM »
In order to calibrate my servo's positions, I need RoboRealm software AND (in order to get the exact "end" positions, like 700 is for centre, i require) HyperTerminal software...
The Problem: I cannot use both softwares at a time, because only 1 Software can use the same COM PORT at a time !
I have modified the Servo_Controller.c, so that when I press the button, Servo1 variable will store the first servo's position, and the next button pressed will store the next servo's position in Servo2 , and so on...
Now, I just want to know, what should I program to store values in variables, SUCH THAT they should remain even after I turn OFF the Microcontroller. (so that I can rprintf the stored values in the next run, while running only HyperTerminal)
Thanks..
Offline z.s.tar.gz
  • Linux Guru
Re: Storing values in Axon Microcontroller?
« Reply #1 on: January 02, 2010, 08:12:08 PM »
The axon is based on an avr chip, so it most likely has some sort of eeprom which doesn't erase with loss of power.
Exactly how you would use it, I don't know as I don't own an axon.
Offline z.s.tar.gz
  • Linux Guru
« Reply #2 on: January 03, 2010, 07:02:23 PM »
As it turns out, the axon is based on the atmega640 which has 4kb of eeprom. (same for the axon 2)
    • RazorConcepts
« Last Edit: January 03, 2010, 07:11:10 PM by Razor Concepts »
« Reply #4 on: January 05, 2010, 01:06:44 AM »
If you get a second USB to serial adapter, you can use a different UART for each. I do this all the time for my stuff.
