Author Topic: help with understanding battry datasheet  (Read 3034 times)
Offline little-cTopic starter
« on: January 27, 2010, 06:06:25 PM »
solved, battery is dead. yay, now to buy a new one >:(
the battery in question is on pages 9 and 10 of this data sheet
http://datasheets.sinus.cz/sosni.php?id=3579
pdf file.
battery part no CGR18650HM
questions;
 how do I tell if a cell is ruined?
 how do I find out what I need to do to charge them?
 can I curl up in a fluffy blanket and hide? :P
automatic brain overload detection cut in and switched my brain off, I have no idea what Im looking at. ::)
« Last Edit: January 30, 2010, 06:33:33 AM by little-c »
Offline madsci1016
  • Helpful? 43
    • Personal Website
Re: help with understanding battry datasheet
« Reply #1 on: January 27, 2010, 06:38:14 PM »
Looks like a standard 18650 Li-ion cell,
If the cell has no voltage, or it's less then lets say 2 Volts, it's likely ruined. Li-ions cannot be discharge beyond a certain point, or they are ruined, which brings me to question 2:
You will need a li-ion battery charger and i highly recommend a Li-ion protection board, because they take care of all the important stuff and make it a pretty idiot-proof power source. They will cut off power when the cells get to low and regulate charge/discharge current. They go for about $9 a board.
Look through this for an idea to turn cells into a usable battery pack:
http://www.billporter.info/?p=154
Offline billhowl
  • Helpful? 32
« Reply #2 on: January 27, 2010, 08:56:28 PM »
This CGR18650HM is standard 18650 Li-ion cell with capacity 1600mAH,
If the cell has no voltage, or it's less then lets say 2.5 Volts, and you charge it for 30 mins and it can't hold any charge, it's likely ruined.
You can charge at constant voltage / onstant current( 4.2V, 1120mA(max) for 2 hours at 20 Deg C).
Refer to this Msg for Charger
http://www.societyofrobots.com/robotforum/index.php?topic=9941.msg76142#msg76142
« Reply #3 on: January 28, 2010, 12:01:32 PM »
okay, this is making sense. Ill have a read through.
