Author Topic: 7.2 volts battery pack with the $50 robot  (Read 2313 times)
Offline TheStoneTopic starter
« on: January 31, 2010, 11:41:42 AM »
Hi
Reading from other posts I have concluded that you should be able to use a 7.2 volt battery pack instead of a 6 volt one for the $50 robot using a resistor to lower the voltage to 6 volts? Right, I haven't missed something?
So I have three battery packs, one at 1400mAh one at 3000mAh and one at 1500mAh, which one would be best to use, and which resistor should I use?
Thanks in advance,
Aron
Re: 7.2 volts battery pack with the $50 robot
« Reply #1 on: January 31, 2010, 01:40:58 PM »
[...] use a 7.2 volt battery pack instead of a 6 volt one for the $50 robot using a resistor to lower the voltage to 6 volts? Right, I haven't missed something?
Wrong!
You want a steady voltage, not one controlled by the current draw.
If you use a voltage regulator in the circuit, you don't need to lower the voltage ahead of it, as the extra cell won't be a problem for the regulator, but unless you use a switching regulator, the extra cell won't give you any advantage over a 5 cell battery (but a bit more weight to drag around).
The larger capacity, the longer the runtime, but the more weight as well.
If your motors/servos can drag it, go for the 3Ah battery.
« Reply #2 on: January 31, 2010, 03:02:33 PM »
Great, so then I can just plug my 7.2 volt battery right in to the circuit (there is a 5 volt regulator in the circuit).
