Author Topic: Optical mouse  (Read 2335 times)
Offline Comrade117Topic starter
  • "War is a joke and a waste of time"
Optical mouse
« on: February 13, 2010, 09:03:20 AM »
I have 1 noob question.  ;D
Optical computer mouse uses laser or LED diode? :-\
Offline little-c
Re: Optical mouse
« Reply #1 on: February 13, 2010, 09:53:41 AM »
led.
at least, the five or so I've taken appart have.
Offline dunk
    • dunk's robot
Re: Optical mouse
« Reply #2 on: February 13, 2010, 11:00:34 AM »
the LED is just for illumination.
the sensor is actually similar to a low resolution camera which actually "sees" the surface it's passing over and works out which way it's moving.
far more going on in your mouse than you thought right?
Re: Optical mouse
« Reply #3 on: February 13, 2010, 03:15:27 PM »
I saw it from inside. It looks simple.  8)
Re: Optical mouse
« Reply #4 on: February 13, 2010, 08:41:30 PM »
Some use an LED, some use a LASER, but the latter will exclaim so in big letters on the carton (and be a bit more expensive).
The best LASER mice can be used on a glass plate or a mirror, as well as on white and black surfaces. They usually has got a much wider depth of field too, but that's probably due to better optics and/or firmware.
