Author Topic: help with cartography! euclidean distance algorithm PLZ HELP!!!  (Read 2661 times)
Offline spgr2Topic starter
« on: February 17, 2010, 10:50:45 AM »
cartography robot euclidean shortest path help!!!?
please help me solving this simple example in robot cartography...
i dont know exactly how the algorithm works!!
lets say we placed a robot in a room and the robot took these measurements for 6 spots:
a = [3 5 9 8 2]
b = [4 6 6 9 9]
c = [1 2 2 3 1]
d = [8 9 2 8 2]
e = [6 3 7 8 3]
f = [9 9 9 9 9]
in order to go from a to e, how the algorithm of euclidean distance will work??
lets assume that spot A connects to B and C, and B connects to D and E, and also C connects to D and E.
and finally D connect to F and also E connect to F
can you please tell me step by step what calculations will the robot do to go from A to F???
please help me!!!!
Offline little-c
Re: help with cartography! euclidean distance algorithm PLZ HELP!!!
« Reply #1 on: February 17, 2010, 01:27:56 PM »
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Understanding_Euclidean_distance_analysis
first google hit. and Im lost. so try reading that, follow a few links.
sorry, I just don't get the algorithm.
« Reply #2 on: February 17, 2010, 01:54:43 PM »
ADDITIONAL EXPLANATION:
Lets assume there is a robot in a room, and for every position in the room (a,b,c,d,e,f) the robot performs a scanning around it with a sonar to see if there is any obstacles. if the value is low, then there is an obstacle (low value means the sound from the sonar got back quickly, high value means that the sound from the sonar traveled longer distance before it went back to robot so there is not obstacle). the robot took 5 measurements for every position (a,b,c,d,e,f) . at the end there is that array i wrote, and then you place the robot at the position a, and you want to go to position f. so the robot must calculate which path to choose. i know that euclidean distance is used to see what point "looks similar" to the target in order to choose the correct path, but i dont know how exatcly it works. if you need more explanation i will respond as quickly as i can, i really need this help!!!
p.s. robot is in 2 dimensional space
p.s.2 an answer will be like "ABEF" like that
p.s. 3 for example the array of position a, a = [3 5 9 8 2] means that in the first measurement which could be e.g. north, the value "3" means there is an obstacle near... the third value "9" could be e.g. "SOUTHEAST" and means there is not obstacle near...
Offline chelmi
    • Current projects
« Reply #3 on: February 17, 2010, 04:22:01 PM »
You need to build a map of the space. e.g. a two dimensional array with each element contains the info "obstacle" / "open".
http://en.wikipedia.org/wiki/Simultaneous_localization_and_mapping
And then you can apply any path finding algorithm you want
http://en.wikipedia.org/wiki/Pathfinding
