Author Topic: 50 dollar robot help - what can i replace ATmega8 AVR with?  (Read 3087 times)
Offline CradboardTopic starter
« on: February 26, 2010, 08:22:14 AM »
basically im trying to build the $50 dollar robot and im in the UK
according to the parts list i need ATmega8 AVR
however it is on backorder only here
http://www.rapidonline.com/Electronic-Components/Integrated-Circuits/Atmel-Microcontrollers/ATmega-8-bit-AVR-Microcontrollers/77086/kw/ATMEGA
can i replace it with any of the others on the list?
many thanks
Re: 50 dollar robot help - what can i replace ATmega8 AVR with?
« Reply #1 on: February 26, 2010, 08:30:36 AM »
ATmega168 and ATmega328 (the latter being the best)
Just make sure you read the upgrade microcontroller tutorial.
« Reply #2 on: February 26, 2010, 08:34:11 AM »
DAMN lol
im enough of a newb as it is and thought id struggle coding this without more complications!!
thank you tho!
« Reply #3 on: February 26, 2010, 08:38:49 AM »
A hundred noobs have done it before you, and asked every possible question a 100 times in the forum, so don't sweat it too much. :P
One person even told me he is now a professional robotics engineer getting paid to make robots, and it all started as a noob building the $50 Robot.
« Reply #4 on: February 26, 2010, 08:45:45 AM »
SWEEEET thanks
« Reply #5 on: February 26, 2010, 08:52:07 AM »
sorry there are 4 ATMEGA168 am i right in assuming its
ATMEGA168-20PU 8-BIT MICRO 16K DIL-28 RC that one
NOT
ATMEGA168V-10PU 8BIT MICRO 16K DIL28 (RC
« Reply #6 on: February 26, 2010, 08:58:26 AM »
The ATmega168 part link is here, silly :P
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
You want a DIP, meaning its for through-hole soldering.
Offline cyberfish
« Reply #7 on: February 27, 2010, 12:53:18 PM »
DIL IS DIP.
Both will probably work, but the 168V is the lower voltage version, which may also be slower.
The first one is more common.
Offline Finnik
« Reply #8 on: February 27, 2010, 01:49:59 PM »
Indeed DIL is DIP and the 168V is the lower voltage version, requiring a minimum of 1.8V instead of 2.7V.
Furthermore, the first (20PU) runs at a maximum of 20 MHz, the second (10PU) will run at a maximum of 10 MHz.
At this moment the difference does not matter for you, for the internal oscillators are the same, but I'd take the 20PU version because of the possibility to run it at higher speeds with an external crystal. You never know when it might come in handy.
Think outside the box... inside is to crowded.
