Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
Hi,Perhaps you should do what other people do and start with something simple, getting to grips with Eagle and over time work your way up to this level of complexity.Both the schematic and the board is loaded with errors, to begin with, don't draw wires through components and don't put junctions everywhere making it look like the target for a 12-Gauge.Start by cleaning that up, then post anew.Oh, and don't change the grid dimension into some strange decimal number, or you won't ever get it to route a board properly.
Quote from: Soeren on March 11, 2010, 11:32:44 PMHi,Perhaps you should do what other people do and start with something simple, getting to grips with Eagle and over time work your way up to this level of complexity.Both the schematic and the board is loaded with errors, to begin with, don't draw wires through components and don't put junctions everywhere making it look like the target for a 12-Gauge.Start by cleaning that up, then post anew.Oh, and don't change the grid dimension into some strange decimal number, or you won't ever get it to route a board properly.hi soren,is nt it necessary to put dots where component pins and wires connect?
[...] and this is my final product.
can you tell me how much distance i should put bet ween two header rows? their pads seems connected each other (between two rows) is there any way to reduce pad size of these headers?
Hi,Quote from: aruna1 on March 13, 2010, 09:44:08 AM[...] and this is my final product.I hope you're not meaning "my final project"?Quote from: aruna1 on March 13, 2010, 09:44:08 AMcan you tell me how much distance i should put bet ween two header rows? their pads seems connected each other (between two rows) is there any way to reduce pad size of these headers?Yes, distance should be 1 module (= 1/10").Make a copy of the library (just to be on the safe side if you Fitup) in eg. Windows Explorer, start Eagle Library Editor and change shape, size and whatever you want - a square pad will probably be the best in your case.If you cannot take the time to learn the basics, the advanced will suffer severely!
The pin headers he chose have long pads and cannot be spaced .1" apart because the long ends will touch.
Download the Sparkfun library and use the circular pad headers.
Quote from: Soeren on March 13, 2010, 09:31:26 PMHi,Quote from: aruna1 on March 13, 2010, 09:44:08 AM[...] and this is my final product.I hope you're not meaning "my final project"?Quote from: aruna1 on March 13, 2010, 09:44:08 AMcan you tell me how much distance i should put bet ween two header rows? their pads seems connected each other (between two rows) is there any way to reduce pad size of these headers?Yes, distance should be 1 module (= 1/10").Make a copy of the library (just to be on the safe side if you Fitup) in eg. Windows Explorer, start Eagle Library Editor and change shape, size and whatever you want - a square pad will probably be the best in your case.If you cannot take the time to learn the basics, the advanced will suffer severely!The pin headers he chose have long pads and cannot be spaced .1" apart because the long ends will touch. Download the Sparkfun library and use the circular pad headers.
