Author Topic: modify servo  (Read 3531 times)
Offline tipipliouTopic starter
modify servo
« on: March 15, 2010, 05:10:19 PM »
hello
i want to modify a servo,i read the toturial but i didn't get this :
"You should probably see the gears rotating without stopping" ,i thought i was supposed to take off all the gears ???
Re: modify servo
« Reply #1 on: March 15, 2010, 11:47:18 PM »
That is after you take the gears out, modify them and put them back in, they should rotate continuously.
Re: modify servo
« Reply #2 on: March 16, 2010, 02:54:27 PM »
ok,i see
well,let's see if i have unterstood  ;) :
i open up the servo,
i take off the largest gear to find the potentiometer
i bring back the others gears(if i've moved them)
i plug in the signal for 0° rotation
i should see them moving continuously
i rotate the pot head till they stop moving
i superglue the pot
i remove the plastic peace from the large gear
i put back the large gear
and this is it
have i missed something?
    • RazorConcepts
Re: modify servo
« Reply #3 on: March 16, 2010, 03:03:02 PM »
You don't have to put the gears back on, just turn the pot until you hear the motor stop moving. Also, the motor should have a teeny gear that doesn't come off, so you can look at that.
Re: modify servo
« Reply #4 on: March 16, 2010, 03:22:50 PM »
ok thanks a lot for your answers
i will probably ask you again,i can't allow my self not doing it well (i don't have enough money ) ;D
Re: modify servo
« Reply #5 on: March 18, 2010, 01:44:18 PM »
hi
i have problem
when i try to center the servo :
 when i applied the pulse for 0° rortation,the gears start moving ,but when i rotate the potentiometer,they don't stop.
it is a HS-422 (hitec)
thanks
Offline richiereynolds
Re: modify servo
« Reply #6 on: March 18, 2010, 02:00:53 PM »
You need to be pretty accurate with the pot, try adjusting it with a pair of tweezers, you should see the gears slowing as you get near the right point.
Re: modify servo
« Reply #7 on: March 19, 2010, 02:04:16 AM »
it's done
thank you very much
