Author Topic: MMA7260QT - Its the same chip but different board - will it work?  (Read 2636 times)
Offline dellagdTopic starter
    • Exodus Rocketry
In WebbotLib's manual, it lists this chip:
http://www.pololu.com/catalog/product/766
But I found it at sparkfun (http://www.sparkfun.com/commerce/product_info.php?products_id=252)and I am ordering other things from them too, so I was wondering if it would work just the same as the one from pololu. Also, in the datasheet from sparkfun it shows lots of capacitors and resisters between the accelerometer and MCU. are all those really necessary?
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
    • RazorConcepts
Re: MMA7260QT - Its the same chip but different board - will it work?
« Reply #1 on: March 18, 2010, 03:20:39 PM »
It should work the same, but the pololu one has a built in 3.3 regulator, the sparkfun does not, so you will need a 3.3v power source.
Also the sparkfun board has all of the resistors and capacitors built on it, so you won't have to add any.
    • Exodus Rocketry
« Reply #2 on: March 18, 2010, 03:25:04 PM »
well, the axonII has 3.3v built in so thats great!
I Won!
