Author Topic: LM338 battery charager help  (Read 7407 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: March 23, 2010, 03:13:23 PM »
hi i made this circuit(taken from http://www.talkingelectronics.com/projects/ChargingNiMH/ChargingNiMH.html),but doesnt seems to work.as i know voltage drop in R should be 1.2v, but in my circuit its about 4V, i tried R values from 1 ohm to 100 ohm,but couldnt get the circuit working,when using 1 ohm current drain was about 2.45A.
my input is from 12V-0V-12V transformer(24V dc using rectifier bridge) and target is charging a 12V 1500mAh NiMH battery pack.
any ideas?
thanks
« Last Edit: March 23, 2010, 03:14:43 PM by aruna1 »
I'm Me
Re: LM338 battery charager help
« Reply #1 on: March 23, 2010, 05:28:25 PM »
Do you have a filter cap after the rectifier?
« Reply #2 on: March 23, 2010, 07:03:10 PM »
yes,220uf
I'm Me
Offline billhowl
  • Helpful? 32
« Reply #3 on: March 24, 2010, 12:22:03 AM »
You may like to try this circuit taken from the datasheet, which limit both voltages and currents to charge the battery. or you can take a look on other charger circuit in the datasheet.
http://www.national.com/mpf/LM/LM338.html
Offline Pratheek
    • Probots
« Reply #4 on: March 26, 2010, 08:53:43 AM »
The LM317 is a linear regulator so it will need an input voltage which is greater than the required output voltage by 2V.
So if you need a 12V output, you will need atleast 14V at the input pin.
