Author Topic: Question for typ in signatur  (Read 2699 times)
Offline PAT_McUserTopic starter
  • I just started with robitic.
« on: April 08, 2010, 03:25:20 AM »
hi, my issue is that I want create a method that returns by given Port and Port_numb a calculation of sensor data.
I want to call with something like
int a;
a=Data(PINA,0);
My question is how the signature of the method Data has to look like for Argument "PINA".
What must I replace the "????" in the following code to get the prog running?
int Data( ???? P, int N)
  int erg;
  if(bit_is_set(P,N)){
    //do something math stuff
  return erg;
PS.: you have to sorry my bad english.
Re: Question for typ in signatur
« Reply #1 on: April 08, 2010, 05:16:09 AM »
Maybe unsigned char is the the solution. I'm will test it in 3-4h.
unsigned char definitely doesn't work.
« Last Edit: April 08, 2010, 09:41:29 AM by PAT_McUser »
« Reply #2 on: April 08, 2010, 09:58:28 AM »
bit_is_set(P,N)
What data type is P declared as in the bit_is_set function?
« Reply #3 on: April 08, 2010, 10:04:30 AM »
bit_is_set(P,N)
I don't know...
« Reply #4 on: April 08, 2010, 01:07:13 PM »
bit_is_set(P,N)
I don't know...
its port, but it doesn't work.
