Squirrels have fuzzy tails.
Hi,There's a shade less than 1/10" pitch in pins 1..3, so that shouldn't be a problem.When making the holes, if you plan to use them for making your own boards, make the holes around 0.3 to 0.5 as you only want to control the drill. If you make a hole of 1.1mm and use a 1.1mm drill, there's a great chance of the hole being slightly offset and some of the copper will end up being a bit of distance from the pin, which will likely give problems with the soldered connection over time and make it harder to solder in the first place.
Hey guys, I can't seem to read this measurement in this datasheet for a product I saw on digikey.Here's the pic..I get most of the measurements, but what's up with the measurements for the hole? One says 3-Ø1.1. What's the Ø mean? Could someone enlighten me?I THINK it means that there are 3 holes with a radius (or diameter) of 1.1 mm. Am I right?
