Author Topic: Axon II Soldering  (Read 4053 times)
Offline adscott1982Topic starter
Axon II Soldering
« on: June 01, 2010, 04:14:01 PM »
Hi Guys,
I just received my Axon II from the USA. Super excited to get started but did a visual inspection and found a couple of the pins were soldered together. I'm not sure if it's intentional or not.
The pins are Bat + and G5 +.
Please find attached images:
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
Re: Axon II Soldering
« Reply #1 on: June 01, 2010, 04:38:14 PM »
Shouldn't be intentional, but you won't have a problem for sure... At least if it's on the same power line... which most possibly is... ;-)
« Reply #2 on: June 01, 2010, 04:40:06 PM »
Oh cool, that makes sense!
Thanks for the info.  :)
Offline TrickyNekro
« Reply #3 on: June 01, 2010, 04:42:42 PM »
Nothing... but take a quick glance at the specs to see if what I told you for the power bus is correct...
If both are Vbat it's ok
If both are 5V it's ok
If both are 3.3V it's still ok...
If they intertwine it's NOT ok...
« Reply #4 on: June 01, 2010, 04:58:40 PM »
According to the datasheet:
http://www.societyofrobots.com/axon2/axon2_datasheet.shtml
They are all Battery, so it should be OK, right?
« Reply #5 on: June 02, 2010, 12:19:25 AM »
Yep, that joint makes that power bus battery voltage.
« Reply #6 on: June 02, 2010, 01:05:45 PM »
Thanks Guys.  :D
« Reply #7 on: June 02, 2010, 09:28:45 PM »
Its a power jumper. If you leave it, you only need one battery. If you remove it, you can power the mcu with a small battery and the servos on the power bus with a different larger battery.
See datasheet for details:
Axon II MCU Power Selection
