Author Topic: ttl to usb  (Read 2652 times)
Offline javilaTopic starter
ttl to usb
« on: June 05, 2010, 11:24:58 PM »
Can anybody recomend me a ttl to usb converter for the 50$ robot or any microcontroller????
Offline Choco_liger
Re: ttl to usb
« Reply #1 on: June 05, 2010, 11:43:11 PM »
It Depends.
Try the AVR ISP mKII programmer if your willing to spend the cash for it. Or you could do a clone of one.
Also you can give the Pocket AVR a shot for less money.
It depends on how long your willing to spend and how long do you think you'll use it for.
Re: ttl to usb
« Reply #2 on: June 06, 2010, 12:27:10 AM »
but those are programmers, I just need an converter ttl to usb...
I was looking at this one: http://www.pololu.com/catalog/product/391
I want to use it with the 50$ robot.. I am not sure about the voltage for the I/O
it says 3.3(5V tolerant).... would that work with the robot/?
Offline Choco_liger
Re: ttl to usb
« Reply #3 on: June 06, 2010, 05:32:37 AM »
Oh Heh, Heh Sorry, wasn't looking.  :D
EDIT: Oops. Sorry, forgot to actually do something.
Why exactly do you need the converter for?
Sorry for my annoying curiosity.
« Last Edit: June 06, 2010, 05:38:18 AM by Choco_liger »
    • RazorConcepts
Re: ttl to usb
« Reply #4 on: June 06, 2010, 05:38:58 AM »
Yes it will work
"you can connect it directly to any microcontroller running at up to 5 V"
Re: ttl to usb
« Reply #5 on: June 06, 2010, 11:51:31 AM »
thank you
Offline Pratheek
    • Probots
Re: ttl to usb
« Reply #6 on: June 07, 2010, 06:51:49 AM »
If you are planning to use the converter for programming, let me tell you, some serial programmers do not work with USB to serial converters. I do not know about the product you have linked.
If you want to do USB programming, then I would suggest you to buy a USB programmer itself.
    • RazorConcepts
Re: ttl to usb
« Reply #7 on: June 07, 2010, 10:11:41 AM »
The converter is for UART data, which isn't used for programming (maybe bootloading, but that will be guaranteed to work). This isn't a usb > serial port converter for programming.
Quote from: javila
