Author Topic: Parts for robot arm, any help appreciated!  (Read 2912 times)
Offline Hal_EmmerichTopic starter
« on: June 08, 2010, 03:47:08 PM »
Hello! I was hoping I could get some advice for how to start building my robot arm.
I am making a robot arm powered by SMA(Shape Memory Alloy) wires. These wires contract when heated, and I am using them to pull a lever to pull up the lower arm like an elbow joint.
I am completely stuck as to where I can buy pieces to construct the upper arm and lower arm, and less importantly a joint for the elbow. I need to make it lightweight, so I was hoping to use plastic parts. Eventually, I will have to add a hand to the design.
Can anyone suggest any places to buy parts, or methods I can use to fabricate my own parts? I saw the link in the tutorial here for www.mcmaster.com. If anyone wants to share any info on McMaster or any other stores I would appreciate it!
Any kind of info is greatly appreciated! Thank you! :)
« Last Edit: June 08, 2010, 03:51:57 PM by Hal_Emmerich »
Offline little-c
Re: Parts for robot arm, any help appreciated!
« Reply #1 on: June 10, 2010, 09:39:40 AM »
find a local hobby shop and get some balsa wood, and glue a little hinge on to two bits of it. if your using SMA wires you wont have a lot of power.
« Reply #2 on: June 12, 2010, 12:28:37 PM »
Thank you for the tip! I was also worried about power issues, but my professors seem to think the wires should be capable of moving a significant amount of weight. The balsa wood sounds perfect for the prototype I am working on, so thank you for the help!  :)
