Author Topic: underwater ROV electronics  (Read 3930 times)
Offline HydrogenTopic starter
« on: June 10, 2010, 04:22:41 PM »
IM looking for some ideas on how to control an underwater rov with a tether.
Topside im thinking about running the RoboRealm software on a notebook, but from there i don't have any ideas.
Ill need some form of tether do carry data.
on the rov, ill need some way to interface 3 ESCs for the motors. I was thinking a http://www.pololu.com/catalog/product/1350  on the ROV with a usb to cat5 converter for a tether?
i also need a way to connect video, a digital compass and a pressure sensor.
any one have any ideas that would involve little programming?
Re: underwater ROV electronics
« Reply #1 on: June 10, 2010, 06:02:02 PM »
Depending on the length of the wire, the bandwidth of the video signal and how much noise you can live with, you may get away with using a single twisted pair in a cat-5(e) - digital signals (control and/or sensor data) may be more or less visible as noise though, so keep a good amplitude on the video signal.
Spend a little extra at a cat-6 cable, if cat-5 is just on the verge of being useable speedvise.
If that won't do, you need to bundle a 75 Ohm coax line with your cat-5 (you can get cables for combined video and signals, but you probably won't like the price tag). go for a cable with a very tightly weaved shielding (i.e. pro quality), but it can be eg. thin cable like RG-179/U (outer diameter = 1.6mm) if distance and bandwidth is fairly moderate.
If you don't wanna program (quite a bit), you're really much better off paying your way to a finished product.
We don't build and program robots to save money, we do it to avoid hanging on street corners ;)
Offline madsci1016
  • Helpful? 43
    • Personal Website
« Reply #2 on: June 10, 2010, 06:11:46 PM »
