Author Topic: Parallax GPS module raw mode reader in C for Baby Orangutans  (Read 3617 times)
Offline scottfromscottTopic starter
  • Me at my Acer Aspire One Net book
    • Scott's Projects
I have completed the main code for reading the $GPRMC strings from the Parallax GPS module in raw mode. This requires parsing the string to extract the data. There are many examples out there, but I haven't found any for the Baby O. So here it is...
A 'raw mode' data reader for the Parallax GPS receiver module #28146 (based on Polstar PMB-248)
for use with the Baby Orangutan robot controller or with slight modifications, other Pololu orangutans
(data stream is captured and parsed) [email protected]
#define F_CPU 20000000UL // Baby Orangutan frequency (20MHz)
#include <math.h>
#include <avr/io.h>
#include <util/delay.h> // uses F_CPU to achieve us and ms delays
#include <pololu/orangutan.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
char gps[650]; // array to store $GPRMS string
//format of Parallax GPS GPMRC string...
//$GPMRC,HHMMSS,A,DDMM.MMMM,S,DDDMM.MMMM,S,KKK.K,HHH.H,DDMMYY,,,A*64<13>
//0123456789012345678901234567890123456789012345678901234567890123456
//          1         2         3         4         5         6
// $GPRMS string locations for following data items...
int utc_hours=7, utc_minutes=9, utc_seconds=11, latitude=16, \
                   latitude_hemisphere=26, longitude=28, longitude_hemisphere=39, speed=41, \
                   heading=47, utc_day=53, utc_month=55, utc_year=57;
void delayms(unsigned int time_ms)
{for (unsigned int i = 0; i < time_ms; i++) _delay_ms(1);
//the following 4 debug functions flash an external LED I attached to #2 pwm motor port
//because the built-in RED LED is not available when the UART is being used
void debug_port(unsigned char pwm)
{  OCR2A = 0;
   OCR2B = pwm;
void debug_init()
{  TCCR2A = 0xF3;
   TCCR2B = 0x02;
   OCR2A = OCR2B = 0;
   DDRD |= (1 << PORTD3) | (1 << PORTD5) | (1 << PORTD6);
   DDRB |= (1 << PORTB3);
void debug_pulse_digit(int digit)
{  // pulse external led 1..10 times depending on value of digit
   // 1 -> 1 pulse; 2 -> 2 pulses; ... 9 -> 9 pulses; BUT 0 -> 10 pulses
   int counter, freq=75, delay=250;
   if(digit==0) digit = 10; // special case for 0
   for(counter=1;counter<=digit;counter++)
   {  debug_port(freq);
      delayms(delay);
      debug_port(0);
      delayms(delay);
   delayms(1000);
void debug(float v)
{  // pulse 6 digits (hto.hto[-]) if negative, single pulse follows 6 pulse sequences
   // example output: -23.5 -> 023.500- -> 10 pulses, 2 pulses, 3 pulses, 5 pulses, 10 pulses, 10 pulses, 1 pulse
   int o,t,h,d,n=0;
   if(v<0){v=-v;n=1;}
   h=(int)(v/100);t=(int)((v-h*100)/10);o=(int)(v-t*10-h*100);
   debug_pulse_digit(h);debug_pulse_digit(t);debug_pulse_digit(o);
   d=(int)((v-h*100-t*10-o)*1000); // .hto -> hto.
   h=(int)(d/100);t=(int)((d-h*100)/10);o=(int)(d-t*10-h*100);
   if(n) debug_pulse_digit(1); // seventh pulse indicates negative
   delayms(1000); //pause between numbers
float get_gps(int request)
{  float r;
   if(request==utc_hours)
      r=(gps[utc_hours+0]-48)*10+(gps[utc_hours+1]-48);
   else if(request==utc_minutes)
      r=(gps[utc_minutes+0]-48)*10+(gps[utc_minutes+1]-48);
   else if(request==utc_seconds)
      r=(gps[utc_seconds+0]-48)*10+(gps[utc_seconds+1]-48);
   else if(request==latitude)
   {  //accuracy: DDMM -- .MMMM ignored; minutes converted to decimal degrees
      r=(gps[latitude+0]-48)*10+(gps[latitude+1]-48)+(float)((gps[latitude+2]-48)*10+(gps[latitude+3]-48))/60;
      if(gps[latitude_hemisphere]=='S') r=-r; // apply sign
   else if(request==longitude)
   {  //accuracy: DDDMM -- .MMMM ignored; minutes converted to decimal degrees
      r=(gps[longitude+0]-48)*100+(gps[longitude+1]-48)*10+(gps[longitude+2]-48) \
           +(float)((gps[longitude+3]-48)* 10+(gps[longitude+4]-48))/60;
      if(gps[longitude_hemisphere]=='W') r=-r; // apply sign
   else if(request==speed)
      //fyi: mph = 6076/5280 * knots ~= 1.15*knots; speed below is in knots
      r=(gps[speed+0]-48)*100+(gps[speed+1]-48)*10+(gps[speed+2]-48)+(float)(gps[speed+3]-48)*0.1;
   else if(request==heading)
      r=(gps[heading+0]-48)*100+(gps[heading+1]-48)*10+(gps[heading+2]-48)+(float)(gps[heading+3]-48)*0.1;
   else if(request==utc_day)
      r=(gps[utc_day+0]-48)*10+(gps[utc_day+1]-48);
   else if(request==utc_month)
      r=(gps[utc_month+0]-48)*10+(gps[utc_month+1]-48);
   else if(request==utc_year)
      r=(gps[utc_year+0]-48)*10+(gps[utc_year+1]-48);
   else
      debug(555);
      while(1); // error
      r = 0;
   return r;
void init_gps()
{  //delayms(40000); //may require delay on cold start for gps module to acquire satellites
   debug_init();
   serial_set_baud_rate(4800);
   char buf[1];
  // request 1 char at a time from gps and copy to char array gps[]
   int gps_index, byte_count;
   for(gps_index=0;gps_index<=649;gps_index++)
   {  serial_receive(buf,1);
  byte_count = serial_get_received_bytes();
  while(byte_count == 0) byte_count = serial_get_received_bytes();
  gps[gps_index]=buf[0];
   //find first instance of "$GPRMC" in gps[]
   char type[6] = "$GPRMC";
   int type_matched = 0;
   int type_index;
   for(gps_index=0;gps_index<=644;gps_index++)
   {  for(type_index=0; type_index<=5;type_index++)
  {  if(gps[gps_index+type_index] == type[type_index]) type_matched=1;
  else
  {  type_matched = 0;
     break;
 if(type_matched) break;
   // upon exit type_matched==1 and gps_index <645 else error...
   if(!type_matched)
   {  debug(555); // my arbitrary error code is 555
      while(1);
   // if we made it this far, everything ok
//move data to start of array...
for(int k=0;k<=65;k++) gps[k] = gps[gps_index+k];
int main()
   init_gps();
   // at this point you  may access gps values captured using 'get_gps(<keyword>)'
   // where <keyword> is any of: utc_hours, utc_minutes, utc_seconds, latitude,
   // longitude, speed, heading, utc_day, utc_month, utc_year
   // return type is float
   // note:
   // [-]longitude -> west of prime meridian, [-]latitude -> south of equator
   //example queries...
   //float lon = get_gps(longitude);
   //debug(lon);
   //debug(get_gps(latitude));
   //delayms(5000);
   //debug(get_gps(utc_hours));
   while(1); // wait forever
   return 0;
« Last Edit: July 07, 2010, 06:02:38 PM by scottfromscott »
Scott Ferguson
[email protected]
  • Helpful? 111
    • Webbot stuff
Re: Parallax GPS module raw mode reader in C for Baby Orangutans
« Reply #1 on: July 07, 2010, 07:26:38 PM »
Hi Scott,
Dont mean to dampen your glory but you can of course use WebbotLib as it already contains the GPS parsing of the main message types including CRC checks
    • Scott's Projects
« Reply #2 on: July 08, 2010, 11:11:00 PM »
Thanks, Webbot
I wasn't aware of WebbotLib but I'll check it out.
Scott Ferguson
[email protected]
  • Helpful? 111
    • Webbot stuff
« Reply #3 on: July 09, 2010, 06:20:55 AM »
Look at my website http://webbot.org.uk as you may also be interested in Project Designer. This application allows you to create a project for the Baby Orangutan and visually drag-n-drop the devices you have got attached (like the GPS). You can even create a software UART for listening to the GPS and keep your hardware uart free for communicating with your pc (or vice versa). It will then generate all the code for WebbotLib to set up and initialise the devices so that all you have to do is concentrate on your main loop code.
« Reply #4 on: July 09, 2010, 01:28:24 PM »
WebbotLib is strongly admin recommended. I rewrote code to all my robots to use it, and donated a bunch of my code to it as well.
(although my code was inferior and he 'cleaned it up' for official use :P)
