Author Topic: how can i connectt a servo directly with a computer  (Read 2294 times)
Offline ballbreakerTopic starter
« on: July 09, 2010, 04:39:25 AM »
not to remember the command just to execute it like calibrating it to go to 0 do i need a microcontroler  or is there another way.
For Those About To Rock, We Salute You!
Offline amando96
Re: how can i connectt a servo directly with a computer
« Reply #1 on: July 09, 2010, 05:12:34 AM »
You can use a parallel port if you have one.
Rorcle, 60% complete
AATV, 5% complete
    • RazorConcepts
« Reply #2 on: July 09, 2010, 06:15:02 AM »
Basically the only way to do it directly is with the parallel port as armando said. However, it isn't the easiest thing to do.
Alternatively you could get a USB servo controller:
http://www.lynxmotion.com/Product.aspx?productID=395
« Reply #3 on: July 09, 2010, 06:20:05 AM »
which of the parallels port pins i use?
« Reply #4 on: July 09, 2010, 06:54:59 AM »
One of the data pins would be the obvious choice, as they are outputs.
But controlling it from Windows will be tough, as you only work with a "Virtual Machine" i.e. timing will be off, so better use DOS or Linux.
