Author Topic: Replacing USB Cable with Bluetooth  (Read 5942 times)
Offline taghaviTopic starter
« on: July 09, 2010, 11:13:56 AM »
Hi.  I am a total newbie.  From my laptop, I drive a simple motorized device through a USB cable which connects to a board that drives several regular motors.  I want to do away with the USB cable. My laptop has Bluetooth. Can I just plug in a USB Bluetooth adapter to my board's USB port?
If not as simple as that, what's the minimum I need to do away with the cable...
Thanks in advance for your help
Offline @Eric
Re: Replacing USB Cable with Bluetooth
« Reply #1 on: July 09, 2010, 11:18:37 AM »
I don't know if it will help you, but here is a tutorial: http://www.lynxmotion.com/images/html/build125.htm
Offline Conscripted
  • Helpful? 10
« Reply #2 on: July 09, 2010, 11:33:08 AM »
I think to answer your question correctly we will need a little more information. What board are you referring to? Is it drawing power from the USB on your computer or is that just a communication medium. If it is just a communication medium and there is a UART available then a simple bluesmirf may do the trick.
There are tutorials for UART and Bluetooth on this site. They may answer your questions. If not provide us with a few more specifics and we will be glad to help.
Good luck
Conscripted
