Author Topic: Pressure Switch  (Read 2475 times)
Offline JdogTopic starter
Pressure Switch
« on: July 23, 2010, 09:00:31 PM »
Hi all. I'm looking for a simple on off switch that is activated by someone stepping on it. I used to have one, it was about 2 feet long and was basically two thin strips of metal separated by Styrofoam, and when someone stepped on it, the metal made contact and conducted electricity.
I now have a project that could use something just like that, although I cannot find any online, I keep finding pressure sensors which is not what I want. Does anyone know what I am talking about, and can anyone find one online that I can purchase?
Offline Gertlex
  • Helpful? 24
    • Index of Oddities
Re: Pressure Switch
« Reply #1 on: July 23, 2010, 10:25:28 PM »
There's foam that conducts.  The more it's compressed, the better it conducts.  Thus it's a variable resistor, sort of.  I've used this method for a small grabber. *shrug*
I
Offline voyager2
  • Helpful? 6
    • Voyager Robotics
Re: Pressure Switch
« Reply #2 on: July 23, 2010, 10:27:28 PM »
This is a pressure sensor:
http://www.sparkfun.com/commerce/product_info.php?products_id=9376
You might be able to attach it to a switch like a transistor or MOSFET, or maybe a relay, it depends on your application.
You could use a momentary contact switch, if you can find one big enough.
What is your application?
And it was good.
Re: Pressure Switch
« Reply #3 on: July 24, 2010, 09:54:28 AM »
McMaster-Carr and other industrial suppliers have pressure sensitive mats.
paulstreats
  • Guest
Re: Pressure Switch
« Reply #4 on: July 24, 2010, 11:54:02 AM »
I made something similar when a was about 12.
All I did was glue kitchen foil to 2 pieces of card, put something in between to seperate them (I made a concertina spring out of more card) and you had some contacts that connected when pressure was added.
 Wire them up to a buzzer and place under a carpet. Great Fun!!!
 maybe you could make something just as simple?
 or you could make a plate that sits over a pushbutton.
Re: Pressure Switch
« Reply #5 on: July 24, 2010, 08:41:10 PM »
I'd make one myself, but if you need something factory made, this comes with a 105 dB siren (at $10)
Re: Pressure Switch
« Reply #6 on: July 26, 2010, 12:29:48 PM »
Thank you everyone who responded.
I think I'm just going to build it myself. What is online is expensive for something as simple as this.
Thanks again ;D
