Author Topic: NXT  (Read 2473 times)
Offline RoboMoonTopic starter
NXT
« on: August 12, 2010, 11:59:01 AM »
I have a littele problem with my NXT 2.0 ...
« Last Edit: September 08, 2010, 02:39:51 AM by RoboMoon »
Offline blackbeard
Re: NXT
« Reply #1 on: August 12, 2010, 12:25:05 PM »
on a first glance it doesn't look like you declared your variables right. for instance instead of writing this
total_time = 0;
wouldn't it be this
int total_time = 0;
Next step: Give them vaginas
    • RazorConcepts
Re: NXT
« Reply #2 on: August 12, 2010, 12:41:52 PM »
No, he declared them right above the task_main() line.
Offline blackbeard
Re: NXT
« Reply #3 on: August 12, 2010, 01:30:17 PM »
Oh i see it. sorry about that.
Offline voyager2
  • Helpful? 6
    • Voyager Robotics
Re: NXT
« Reply #4 on: August 13, 2010, 12:58:55 AM »
Think before write!
RoboMoon, I suggest you stick with LEGOs GUI programing...
everything is better with GUI.
Doesn't mean I'm not a fan of DOS...
And it was good.
Offline awally88
Re: NXT
« Reply #5 on: August 14, 2010, 07:48:31 AM »
@Voyager2 I installed a java machine on my NXT brick. It makes everything so much nicer to use than the Lego GUI.
@RoboMoon Have you tried something even more basic? I've never used Bricx but try using something heaps simple like turning on a motor forever.
task main()
      while (1); ///Keep Running forever
           OnFwd(OUT_AC, 70); //Set motor going forward
Offline voyager2
  • Helpful? 6
    • Voyager Robotics
Re: NXT
« Reply #6 on: August 15, 2010, 06:41:41 AM »
Now I am trying to learn NXC but in the mean time, I've become a LEGO NXT-G master...
@RoboMoon i suggest you use NXC, it's based on C.
If you are a "hardcore" NXTer you can probably figure out how to program the ARM and AVR.
Can't remember the name of the ARM but both it and the ATmega48 (which controls the servos) are made by ATmel.
« Last Edit: August 15, 2010, 06:47:10 AM by voyager2 »
And it was good.
