Author Topic: soldering mistake?  (Read 2432 times)
Offline Melcin PowellTopic starter
soldering mistake?
« on: August 17, 2010, 10:16:50 PM »
What happens if you connect a pin with an empty brass ring? Does it effect it in a negative way? This is off topic but on the $50 robot the 10 pin male headers do i bus the power to all the pins? or just the one further from the dip socket, and if your busing power it doesn't matter what pin your connected too as long as all the pins are connected together right?
« Last Edit: August 17, 2010, 10:31:25 PM by Melcin Powell »
Offline blackbeard
Re: soldering mistake?
« Reply #1 on: August 18, 2010, 05:59:19 AM »
by empty brass ring do you mean one of the holes in the breadboard? if so then no. as long as nothing else is touching that connection then it's fine. as for your other question i'm not sure what you mean probably since i haven't done the $50 robot. if you mean does it matter what you pins you connect to the header in which order then again, no. the only thing about that is that you want it to be somewhat sensible so if you put all the pins in order then you'll have a much easier time later in life when you dig it out of your parts bin and want to use it in your project
Next step: Give them vaginas
« Reply #2 on: August 18, 2010, 06:26:15 AM »
To the second question, the four outer rows of pins should be connected in singular rows to form power buses, yes?
« Reply #3 on: August 18, 2010, 03:03:51 PM »
This picture is from the website, but i am talking about the pins on the bottom left the left column is connected by solder right but the one on the right isn't? When i attach a wire to a power bus it doesn't matter what pin the wire is closet to right?
« Last Edit: August 18, 2010, 03:05:43 PM by Melcin Powell »
« Reply #4 on: August 18, 2010, 04:40:20 PM »
yes, the one on the right is the programmer header, bridging that would be quite bad imo...
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
« Reply #5 on: August 20, 2010, 08:31:44 AM »
This series of blog posts might help. It is an alternate build of the board. This build uses the 6-pin ISP header instead of the 10-pin. It is an alternate set of photos/diagrams that you can study and compare. Perhaps it will help clear things up for you.
http://circuitgizmos.com/wordpress/?p=471
