Author Topic: doubt about H-bridge..  (Read 2273 times)
Offline royalbird.ramanTopic starter
« on: August 28, 2010, 12:47:44 AM »
sir,
I am an ICE student 1st year Delhi University.I am new to robots.srry not even new, i started studying microcontrollers on my own.
I have a doubt in H-bridge whose link is given below.If A=0,B=1 ,then the some current should enter B->A->gnd. Now if the answer is diode,then wouldn't this diode stop the current entering A when A=1,B=0.
srry if i asked a stupid question..I u can help,I will be thankful to u.
http://www.societyofrobots.com/schematics_h-bridgedes.shtml.        ----->link of H-Bridge diagram.
« Last Edit: August 28, 2010, 12:49:01 AM by royalbird.raman »
Re: doubt about H-bridge..
« Reply #1 on: August 28, 2010, 08:21:08 PM »
Current will not pass through a MOSFET when the gait is turned off. So if A=0, no current will pass through it :P
« Reply #2 on: August 29, 2010, 06:27:36 PM »
It seems that it's drawn with N-ch devices only.
(Always use P-ch devices at the top, or you'll need a higher voltage than the motor voltage to drive them).
Offline macdad-
    • LoneWolf's Circuits
« Reply #3 on: August 30, 2010, 05:13:16 PM »
To second that, follow the rule of "Collector to load" always have the collector facing to the load(or drain if using mosfets)
« Reply #4 on: August 31, 2010, 04:21:28 PM »
agreed . . . i saw that mistake like 4 years ago and still haven't fixed it . . . maybe I should do that now . . . lol
