Author Topic: motor  (Read 2556 times)
Offline RoboMoonTopic starter
motor
« on: September 03, 2010, 04:38:07 PM »
different motors ...
« Last Edit: September 08, 2010, 02:35:01 AM by RoboMoon »
Re: motor
« Reply #1 on: September 03, 2010, 07:14:47 PM »
5
Re: motor
« Reply #2 on: September 04, 2010, 05:14:10 AM »
Offline amando96
Re: motor
« Reply #3 on: September 04, 2010, 06:41:47 AM »
dif·fer·ence
n.
6. Mathematics
a. The amount by which one quantity is greater or less than another.
6 - 1 = 5
Rorcle, 60% complete
AATV, 5% complete
Re: motor
« Reply #4 on: September 05, 2010, 01:14:54 AM »
Thanks ...
« Last Edit: September 08, 2010, 02:35:55 AM by RoboMoon »
Offline voyager2
  • Helpful? 6
    • Voyager Robotics
Re: motor
« Reply #5 on: September 05, 2010, 01:54:35 AM »
10 tooth gear on the left meshed with a 60 tooth gear on the right, then the gear ratio is 1:6.
1 turn of the 10 tooth gear = 6 turns of the other gear.
But in physics, and science you can't get anything free, so the 60 tooth gears torque has 6 times LESS torque than the 10 tooth gear.
Now if you had a 60 tooth gear on the left, meshed with a 10 gear on the right, then the gear ratio is 6:1!
6 turns of the 10 tooth gear = 1 turn of the 60 tooth gear.
The 60 tooth gear has 6 times as much torque, but 6 times LESS speed.
To sum it up in an easy to remember sentience:
1 turn of the big gear = 1/2 a turn of the little gear.
Hope this helps!
And it was good.
Re: motor
« Reply #6 on: September 05, 2010, 08:32:35 AM »
Its the other way around.
Drive 6 turns of the 10 tooth gear equals 1 turn of the 60 tooth gear for a 6:1 speed reduction and torque increase.
Re: motor
« Reply #7 on: September 05, 2010, 11:14:43 AM »
Thanks ...
« Last Edit: September 08, 2010, 02:35:27 AM by RoboMoon »
Re: motor
« Reply #8 on: September 05, 2010, 11:25:07 AM »
We need a better explaination of what you are talking about.
What are spindles?
spindle 1 to spindle 6?????
What does this mean?
