Author Topic: Sabertooth Connection help  (Read 2274 times)
Offline moltrex84Topic starter
« on: September 10, 2010, 08:12:30 AM »
Hello,
I have a sabertooh and I'm following the tank control example to be tested in a axon2 ...
Which configuration should I use for this.
1-   Which Port in the microcontroller ???  UART 0 ??? What baud rate if need it ??
2-   Which configuration in the Motor drive ??? Simple serilazed ???
3-   Which Port in the Sabertooth S1 and S2 or only S1 ???
Help will be gladly accepted … I will post a cool video of what I’m doing if I get this solve …
Thanks,
Offline tmoney68
Re: Sabertooth Connection help
« Reply #1 on: September 13, 2010, 03:08:24 PM »
If you g to he dimension engineering website http://www.dimensionengineering.com/ there are wizards to help you set up the dip-switches for the different configurations And the documentation (which is a pdf file) will tell you how to hook up the sabertooth.
As far as which UART, I don't have an Axon2, but I'm sure it is labelled on the board.
  • Helpful? 111
    • Webbot stuff
« Reply #2 on: September 14, 2010, 05:41:19 PM »
Well if you are using WebbotLib and the Project Designer tool then it shows you what to connect to where, DIP switches etc.
