Author Topic: Noob Eagle CAD Questions  (Read 4220 times)
Offline donggyuTopic starter
« on: September 22, 2010, 04:47:19 PM »
I think I might want to start designing my own pcb boards, and I have a some questions:
-Why do you people design pcbs and send it to a fabhouse where they make it for you? What does the fabhouse do?
-What is the arrow symbol in the green/red schematic? Why are the grounds often not connected to anything?
Thanks!
-Donggyu
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Noob Eagle CAD Questions
« Reply #1 on: September 22, 2010, 05:19:42 PM »
You should read the SparkFun Beginning Embeded Electronics tutorials:
https://www.sparkfun.com/commerce/tutorials.php
« Reply #2 on: September 22, 2010, 07:37:37 PM »
Thanks! My question relating to the arrow symbol and the fabhouse is still unanswered though. Can you please explain it to me?
Offline rbtying
  • Helpful? 31
« Reply #3 on: September 22, 2010, 10:50:35 PM »
Arrows are usually GND, as the CAD program will connect the GND and VCC for you.
« Reply #4 on: September 23, 2010, 01:23:49 PM »
So the arrows AND the traditional ground sign is GND? Confusing..
Offline rbtying
  • Helpful? 31
« Reply #5 on: September 23, 2010, 02:46:49 PM »
Which arrows are you talking about?  Normally the one that seems to point off into nowhere ( ->) is GND, as the CAD program connects those.  I'm not really aware of other arrows.
    • RazorConcepts
« Reply #6 on: September 23, 2010, 03:30:59 PM »
From my experience arrows typically face upwards and indicate VCC
Offline galannthegreat
« Reply #7 on: September 23, 2010, 04:50:26 PM »
Here's a picture that shows some of what you mean. (there are other symbols, but these are some of the most commonly used, though I am familiar with with the up arrow as Vcc, don't know why it isn't here)
Kurt
« Reply #8 on: September 23, 2010, 05:03:35 PM »
Oh ok. What is the difference between a signal ground and a power ground?
Offline Ro-Bot-X
  • Helpful? 25
    • Ro-Bot-X Designs
« Reply #9 on: September 23, 2010, 05:37:42 PM »
The other members answered tour arrow question.
We send the boards to the fabhouse because they can fabricate them cheap. For instance, 10 boards up to 5cm x 5cm are $20 to make. If you can do one board in one hour at the quality of a fabhouse for $20 then do it by all means. I would pay myself to do it at least $10 per hour, as it will not have plated holes and solder mask. To make a board you need tools, like a drill press capable to hold and drill with tiny bits, a laser printer for the toner transfer, chemicals to etch the board, then again toner transfer for a silk screen. Not worth it in my  opinion. If you only want one board, go to BatchPCB at SparkFun and get it for about $15.
