Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
I'm planning on interfacing this to an ArduinoI was wondering if I could control 16 servos with it. I'm building a Biped with arms.
I'm planning on interfacing this to an Arduinohttp://www.sparkfun.com/commerce/product_info.php?products_id=9056I was wondering if I could control 16 servos with it. I'm building a Biped with arms.
By chance, I recently started this 1/8 servo expander.
By chance, I recently started this 1/8 servo expander. It hasn't been prototyped yet, but any issues will be in timing (if so, component values will just need a little fine tuning).Please remark that it takes a slightly different signal than an ordinary servo to control the timing (described in the schematic).When it's matured, perhaps webbot could be persuaded to include a control sub-procedure in his library.
NO. read the description again. This board is mostly analog inputs with four digital outputs so it could be used for four servos.A serial port expanded could be used to control 16 servos but the board you linked to is not one.
FYI - The board that I mentioned in the earlier post used two of the 4017s for up to 18 servos... Each one can control 9 servos with one channel left for the wait until the next grouping.
That looks like a PPM decoder:[...]correct? Or what's the difference?
Quote from: KurtEck on October 04, 2010, 10:23:38 AMFYI - The board that I mentioned in the earlier post used two of the 4017s for up to 18 servos... Each one can control 9 servos with one channel left for the wait until the next grouping.It's way more practical to be able to hold the info in a single byte - hence the 8 line limit in my design (I do think a little when I design circuits ).Controlling 18 servos on a single line... Well, each could potentially be 2ms (=36 ms), so the repeat rate of 20ms wouldn't be guaranteed.
It sure does... Why do you ask?
Actually this board takes 4 io pins. 2 for each chip. One for the clock and one for an enable. The enable allows you to turn the whole servo system on or off...
[...] it makes very little difference between 8 or 9 servos. Just an extra 2 byte value in the array to hold the desired pulse width...
