Author Topic: compass module  (Read 3156 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
compass module
« on: December 03, 2010, 07:53:09 AM »
Hi
I'm thinking of buying a compass module for my robots
cheaper one will be better.
I have no idea what are the things i should consider when buying a compass.
can someone help me here
thank you
I'm Me
Re: compass module
« Reply #1 on: December 03, 2010, 08:59:56 AM »
What are your requirements for the Compass?
Just a heading on level terrain?
Or do you need a heading with the Bot tilted?
SparkFun carries several:
http://www.sparkfun.com/search/results?term=compass&what=products
I have used the Compass Module - HMC6352 with reasonable success.
http://www.sparkfun.com/products/7915
Re: compass module
« Reply #2 on: December 03, 2010, 09:05:51 AM »
well most of time it would be used on flat terrain.anyway much of tilt this can compensate? I mean evan we thought terrein is flat it can be laces we cant identify
I'm Me
Re: compass module
« Reply #3 on: December 03, 2010, 09:23:05 AM »
I'm Me
Re: compass module
« Reply #4 on: December 03, 2010, 09:41:32 AM »
I guess you could if it is fully documented. It does have a UART (asynchronous data) which is a little easier to interface to a uController than the I2C used by the other compass modules.
Re: compass module
« Reply #5 on: December 03, 2010, 10:11:09 AM »
Hi
I have attached datasheet here
http://www.sure-electronics.net/download/down.php?name=DC-SS504_Ver1.0_EN.pdf
can you please take a look at this?
I'm Me
Re: compass module
« Reply #6 on: December 03, 2010, 11:10:50 AM »
Well the data sheet does look to be complete. A couple of things to note:
1- It seems that the UART interface is only used to initialize calibration and set the local magnetic deviation and is the only way to do these functions.
2- To read the magnetic data I2C must be used. The data sheet seems to explain how to do the I2C sequence in detail.
3- The SET & RESET of the magnetic sensor elements must be done by the Master processor (its not automatically done internally by the compass)
Re: compass module
« Reply #7 on: December 03, 2010, 08:28:43 PM »
so in that case this sensor (without i2c) (more cheaper than previous) will also do the trick right?
I mean with both sensors I have to use I2C
and what is this dual axis thing?
http://cgi.ebay.com/Dual-axis-Magnetic-Sensor-Module-2-c-Interface-/230558944655?pt=LH_DefaultDomain_0&hash=item35ae624d8f
I'm Me
Offline UAE
Re: compass module
« Reply #8 on: December 04, 2010, 10:34:39 AM »
I have never used them before but I'm planning to use them and I was reading a lot on them
From what I understood,
It depends on your application
there are 2(dual)-axis and 3-axis compasses and it depends on your application
If you are going to use it on a flat terrain then 2-axis will be good
If you may use them on rugged terrains (sand, grass, eg.), a 2-axis compass might give you inaccurate data because of the tilts and in this case you might need a 3-axis compass
