Author Topic: Possible $50 Robot Issue?  (Read 3016 times)
Offline arrrrgonTopic starter
« on: February 07, 2011, 10:51:50 PM »
So I finally finished the board for my robot (I haven't added the photosensors yet).  I was able to communicate with the atmega8 and I uploaded the hex file that is supposed to make the servos go to the 0 position.  I am using the hs-311 from the tutorial.  After I upload the hex file to flash, the servos begin to vibrate and the wheels just shake slightly back and forth.  Did I do something wrong?
Offline greywanderer012345
Re: Possible $50 Robot Issue?
« Reply #1 on: February 08, 2011, 11:41:34 AM »
If you manually turn the servos when everything is off, do they rotate until centered when you turn everything on?
« Reply #2 on: February 08, 2011, 02:05:47 PM »
I had screwed the servo wheels on wrong, so it was actually moving, but I couldn't see it.  Once I took it apart I realized what I had done and now everything is working.  It was a user error.  Thanks for the help though.
