Author Topic: AVR ISP Mk2 won't connect to my 50$ robot board  (Read 2433 times)
Offline rabadswompeTopic starter
« on: February 08, 2011, 07:04:30 PM »
I've posted this question on an other thread but realized it isn't about the same problem.
My board is finished, AT mega 8 is in, batteries are in, no shorts. I've follewed the diagram to do all the connections (the one that duplicates a board with superposed circuits you can remove or add). THe wiring is made for a 6 pin ISP connection
I connected toe AVRISP M2 to the computer's USB and to the board with power on. 2 green leds turn on inside the ISP.
I open AVR Studio 4 (downloaded in 3 parts from the tutorial). I bring up the hold_servo .hex
System is in simulator/at mega 8. I try to select the AVR IPS Mk2 and USB in the connection menu (from the black icon in 2nd tool bar). The request is rejected. I can't connect.  The only way I can access the "program" window is by clicking "work out of connection"...wich doesn't get me far.
SOS...help... I need to continue and mod those servos!!!!
« Last Edit: February 08, 2011, 07:05:41 PM by rabadswompe »
Re: AVR ISP Mk2 won't connect to my 50$ robot board
« Reply #1 on: February 09, 2011, 12:25:23 PM »
ok... found in an other post that new (2009) AVRISPMkII have a problem with the older versions of AVR studio 4 that is downloadable from the tutorial and that downloading strait from AVR solves that communication problem. Will try and see.
If you have other ideas... feel free to chime in!
« Reply #2 on: February 11, 2011, 01:53:34 PM »
ok... I updated the software with a download from the atmel website. right off, I could access the programming page... I then tried to upload the hold_sevo .hex file
I got the orange blinking light. The help menu said I've got a short on the MOSI or that I wired the ISP connection wrong.
I rechecked and , to me, all seems connected as per the diagram. I've check for shorts with the multimeter... no false connections. Frequency is 125mhz...
I thought I could progress today but it seems I need to fiddle some more before I get this robot rolling.
Going to see previous post about that orange ISP light... maybe something in there can help.
Edit: there was ibndeed a tuiny fleck of solder shorting the MOSI pin for the ISP. That was an easy fix. I also removed and resoldered my %v regulator and now all is ok. It was then easy to modif the 2 servos for 360 rotation.
« Last Edit: February 14, 2011, 09:28:26 AM by rabadswompe »
