Author Topic: 10 pin header $50 robot  (Read 3897 times)
Offline Melcin PowellTopic starter
« on: February 17, 2011, 09:50:52 PM »
Does the Atmel AVRISP mkII come with the 10 pin adaption or do i need to buy that separately
Offline hoosier122
Re: 10 pin header $50 robot
« Reply #1 on: February 17, 2011, 11:46:03 PM »
You only need 10 pins if you have an old dongle. The newer ones (past 3 years at least) are all 6 pins.
Here is a link that explains it.
http://www.societyofrobots.com/robotforum/index.php?topic=1045.0
« Reply #2 on: February 18, 2011, 01:43:04 AM »
That is all fine and dandy but i already soldered in the 10 pin that is why i was wondering?
Offline hoosier122
« Reply #3 on: February 18, 2011, 02:02:33 AM »
The dongle's plug will only have six holes in it. You'll have to re-solder it for the six-pin configuration. You can't just only plug it into the six pins on the right or left. I hope this makes sense.
Offline dmclifton
« Reply #4 on: February 18, 2011, 08:20:25 AM »
Sure he can - he simply needs to wire only the top six pins and put the connector in correctly, and ignore the other pins.
« Reply #5 on: February 18, 2011, 12:06:50 PM »
Thanks for the tips guys but out of the box the Atmel AVRISP mkII comes with a six pin how could i put a 10 pin on it do i have to buy that part separately.
Offline hoosier122
« Reply #6 on: February 18, 2011, 03:03:25 PM »
Forget 10 pins.
Follow the directions in this thread: http://www.societyofrobots.com/robotforum/index.php?topic=1045.0
You will only need six pins.
Offline hoosier122
« Reply #7 on: February 18, 2011, 03:05:01 PM »
He can plug into the six on the right or left AFTER he rewires it, but he must rewire it by following the directions that I linked.
I recommend only having six pins on the header, so he won't be confused.
« Reply #8 on: February 19, 2011, 12:16:06 AM »
OK again i appreciate the post but please just anwser this question do if I buy the Atmel AVRISP mkII do i have to buy the 10 pin adaption separately
Offline hoosier122
« Reply #9 on: February 19, 2011, 12:30:59 AM »
I'm not aware of a 10-pin adapter. Please post a link to that.
Offline dmclifton
« Reply #10 on: February 19, 2011, 10:54:24 AM »
I think what people are trying to tell you is -
The 10 pin is an old connection not used anymore by that programmer.
They all have 6 pin now.
So either buy some other programmer that will do what you want which is 10 pin, or rewire it. Changing the wires to fit for the six pin is the better option.
Do you understand?
