Author Topic: Need Enclosure Latch  (Read 2991 times)
Offline OcelotTopic starter
« on: February 18, 2011, 12:47:39 PM »
Hey all,
I couldn't find a project enclosure that fit my application so I ended up building one from ABS sheet plastic. It has a two sections a top and bottom section that are connected on one side by hinges (so they open like a book). All the electronics are in the top section and all the motor/solenoid valves are in the bottom section.
I was wondering if anyone had any ideas or could refer me to some products that would allow me to latch the two sections shut. After some extensive googling, I haven't been able to find anything that can do the trick.
Any suggestions would be helpful!
Thanks,
Brian
Re: Need Enclosure Latch
« Reply #1 on: February 18, 2011, 01:39:57 PM »
That is a tough one. I'd start with the local hardware store to see what they may have.
Another source would be McMaster-Carr.
One idea would be a quarter turn fastener.
http://www.mcmaster.com/#quarter-turn-fasteners/=b38ud2
If you don't need to open the covers often then maybe just a couple of screws.
« Reply #2 on: February 19, 2011, 11:17:35 PM »
Apart from all the hardware that you'd use on doors, tool boxes, suitcases, ladies purses etc. you might wanna consider using strong magnets for holding the box closed, either directly, or by holding a catch in place.
