Author Topic: 50$ robot only one servo is working  (Read 3259 times)
Offline backmanTopic starter
« on: February 22, 2011, 10:06:56 AM »
I have a little problem with my 50$ robot. I do everything what is in HOW TO and when i power it up only one servo is acctually responding on changes of light. Another one is still going in one direction. It's not fault of the servo because when I give there another one it's doing the same. Any ideas where the problem can be?
Sorry for my bad english.
Re: 50$ robot only one servo is working
« Reply #1 on: February 22, 2011, 10:15:30 AM »
Re-check the output of the LDR sensors with a voltmeter.
Also, go through the forum threads (search '$50 robot') and read what other people have had problems with and the solutions.
Offline arrrrgon
« Reply #2 on: February 22, 2011, 10:29:17 AM »
Make sure your grounds are connected properly.  This caused me problems.
Offline hoosier122
« Reply #3 on: February 23, 2011, 10:48:38 PM »
Switch the servos. That will tell you if it's a problem with the servo or circuit feeding the problem servo. My guess is it's a problem with one of the light sensors.
« Reply #4 on: February 24, 2011, 05:37:43 AM »
Yes is it problem with one of the light sensors. When I checked the output one of them has 1.9V the second one has 0.4V. When I tried other light conditions the second one changed just a little bit to 0.5V. Where can problem be? I tried switched resistors and didn't help.
« Reply #5 on: February 24, 2011, 07:15:42 AM »
It was microcontroller problem. Thanks
Offline dmclifton
« Reply #6 on: February 24, 2011, 09:07:06 AM »
Would you be willing to clarify? 'microcontroller problem'? Just curious.
« Reply #7 on: February 24, 2011, 09:52:18 AM »
When I changed atmega8 for another one. Then it worked. Probably one of the pins was wrong.
Offline hoosier122
« Reply #8 on: February 24, 2011, 10:48:45 AM »
Was it bent and not making contact?
I'm surprised it worked at all if there was a problem with the micro-controller....glad you got it figured out.
« Reply #9 on: February 24, 2011, 02:04:08 PM »
No it wasn't at all. I tried every contact with multimeter if there is contact and everything was OK. I am suprised too. But it is working and that's important
« Reply #10 on: February 26, 2011, 05:22:21 AM »
The problem is not solved. When I tried it today it just didn't work properly. When I give light to one photoresistor just one servo reacted. But I noticed when I unplug the good one servo the bad one is working well. When I plug it back again it doesn't work.
EDIT: I changed the LED because the old one was burned out. When I give there another one I found out there is some problem with power because the LED just blink and then nothing. I tried multiple power sources but still it is doing the same.
« Last Edit: February 26, 2011, 06:47:08 AM by backman »
