Author Topic: Axon, arduino, and cellbot  (Read 2629 times)
Offline KylepowersTopic starter
« on: March 12, 2011, 11:28:49 PM »
Can you either use a android cellphone with cellbot software on it with the axon microcontroller? Or would you need to use an arduino board to ttl the commands to the axon that are received by the cellphone to be sent to the axon?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Axon, arduino, and cellbot
« Reply #1 on: March 13, 2011, 06:20:56 AM »
The connection to the phone is similar with the connection to the PC. If you look at the Cellbots site, you will see that they have the phones working with all sorts of hardware: Lego NXT, iRobot Create, Arduino. So you can modify the code for any of the last two and put it in the Axon and it will work. Use the Designers to generate your hardware code, then add a simple loop that reads your serial comm (use a Bluetooth device or a serial adapter like the one from Sparkfun) for commands and sends them to the motors and servos. Also, you can add sensors and either use them internally for object avoiding, etc. or send the readings back over the serial to the phone and deal with them in your App.
