Author Topic: No Parity, 2 Bit Stop  (Read 2661 times)
Offline stlmarcTopic starter
« on: March 14, 2011, 01:54:46 PM »
Hi Axon guru's,
     How do I set my uart2 with a no parity, 2 bit stop ? I need it to improved my serial connection with my LCD Diplay.
I can see my byte sent to the display but I have some other noise or byte that  I don't sent.
my display need  a no parity, 2 bit stop on 9600 baud
Regards
« Last Edit: March 14, 2011, 03:50:10 PM by stlmarc »
Re: No Parity, 2 Bit Stop
« Reply #1 on: March 14, 2011, 07:19:20 PM »
With PICs parity is calculated in software and set into the 9th bit. 2Stop bits can be done with a one bit time delay between characters.
« Reply #2 on: March 16, 2011, 03:45:24 AM »
Sorry I fogot to specify the MCU I work with.
   My MCU is a Axon and my LCD is a Devantech LCD03.
  • Helpful? 111
    • Webbot stuff
« Reply #3 on: March 16, 2011, 02:15:39 PM »
WebbotLib supports the Devantech LCD03 .
I used the I2C interface coz its faster and is less prone to sending spurious glitch characters that end up re-programming it by mistake.
