Author Topic: Cheapest method to connect $50 to USB port.  (Read 2436 times)
Offline ConscriptedTopic starter
  • Helpful? 10
« on: March 31, 2011, 02:52:54 PM »
hello all. I'm looking for the cheapest method I can find to connect the $50 robot to a USB port on the computer. I don't need it for uploading software. I have the AVRISPMKII for that.
I've done several searches and looked a various options but I'm never really sure what will work and what won't. I'm hoping to get a solution that others have used before.
Conscripted
Re: Cheapest method to connect $50 to USB port.
« Reply #1 on: March 31, 2011, 04:19:44 PM »
I guess an USB to EIA/TIA232 adapter is about the cheapest. Search this site, I think somebody posted about hacking a cheap DealExtreme adapter cable recently.
Offline totalis
« Reply #2 on: April 01, 2011, 05:55:20 PM »
Having spent a long time messing about with f232rl chips, i now realise that the best way is to order a nokia data cable (CA-42)
you then can open up the USB part and resolder the V++ and GND, the other conections should be in the same place. i did this because the power out was 3.3v and not 5 like i tend to use. the other end can be cut and made into a pin header.
I would recommend using some 2.2k resistors inbetween the data lines and the pins, this stops the chip from frying if connected the wrong way.
the original post is here
http://www.societyofrobots.com/robotforum/index.php?topic=12751.0
http://cgi.ebay.co.uk/CA-42-USB-DATA-CABLE-NOKIA-5100-5140-6020-6021-CA42-/220600266404?pt=UK_MobilePhones_MobilePhoneAccesories_MobilePhoneDataCables_JN&hash=item335ccceea4
Ebay uk
Hope this helps
if you need driver help then reply of PM me
T
Offline tcousins
« Reply #3 on: April 09, 2011, 12:04:19 PM »
There many device available but since you are looking for the method to connect to a USB port try searching for crude usb interface.  These circuits are easy and cheap to build.
Your Source For Embedded Supplies
Cheap Embedded Parts & Sensorshttp://www.embeddedsupplies.com
paulstreats
  • Guest
« Reply #4 on: April 09, 2011, 05:01:48 PM »
Maybe just replacing the MCU with a USB capable one would be the most straight forward option.
  • Helpful? 10
« Reply #5 on: April 10, 2011, 08:04:34 PM »
I've already gotten the $50 board built. Changing MCUs isn't an option.
