Author Topic: Threading rod that needs to be perpendicular  (Read 4535 times)
Offline AsellithTopic starter
  • Helpful? 9
    • CorSec Engineering
« on: April 07, 2011, 05:42:25 PM »
So I am trying to tap acrylic and screw a threaded brass rod into it. I'm having trouble getting them to be perpendicular when connected. I'm tapping and cutting the threads by hand. Any suggestions or tips?
Jonathan Bowen
CorSec Engineering
www.corseceng.com
Re: Threading rod that needs to be perpendicular
« Reply #1 on: April 07, 2011, 06:16:06 PM »
A drill press is probably the easiest way - just turn the chuck by hand and watch the z-axis.
Offline MikeK
« Reply #2 on: April 07, 2011, 09:51:23 PM »
Make or buy a tapping guide.  It's a block that holds the tap perpendicular to the surface it rests on.
  • Helpful? 9
« Reply #3 on: April 08, 2011, 09:19:43 AM »
Thanks Soeren. About 10 mins after I posted I tried my drill press and it worked great. I used it for tapping the holes but didn't think of it right away for die cutting the rod. I just tossed it in the chuck and it worked great.
Now if I can find a source for various lengths of stainless rod with a small amount of thread on them then I will be set. Prototypes are ok but production runs of these are going to be a pain.
Jonathan Bowen
CorSec Engineering
www.corseceng.com
« Reply #4 on: April 08, 2011, 09:56:55 AM »
Threading the end of a rod can be done in a lath.
For production you may want to have a local machine shop make these. It could be cheaper when you consider your own labor cost.
  • Helpful? 9
« Reply #5 on: April 08, 2011, 10:27:09 AM »
I'm going to look into that option but I don't know if I can do it for the cost I need. Just cut to length steel is pushing my price limit at roughly $0.25 a unit for 2" stainless. I'm looking into alternative parts that might work. For instance an R/C car push rod with threaded ends could work if I can find the right one and get them from a distributor without having to go through a retailer.
This is plan B because I wanted to do something with clear acrylic rods but they are not strong enough.
Jonathan Bowen
CorSec Engineering
www.corseceng.com
« Reply #6 on: April 08, 2011, 07:59:09 PM »
Not sure of what gauge you need, but perhaps bicycle spokes could be used - not sure how much they are in your end of the world either, but I would guess them cheaper than R/C rods.
A small shop with a CNC would probably be the cheapest, but you'd have to order enough to spread the setup cost.
