Author Topic: Need to be smarter than the transistor  (Read 2394 times)
Offline joe61Topic starter
« on: April 13, 2011, 04:59:13 PM »
I'm trying to understand transistors. In that effort I ordered some stuff to try to build an H-bridge as described at http://www.mcmanis.com/chuck/robotics/tutorial/h-bridge/bjt-impl.html
The transistor is a TIP 107 PNP. The data sheet linked to from Digi-Key ( http://www.onsemi.com/pub_link/Collateral/TIP100-D.PDF ) doesn't give the pin functions, but I'm assuming that pin 1 is base, 2 is collector and 3 is emitter, is that right?
I'm stuck on the first little schematic at the top of that page. I might be misunderstanding the schematic and wiring it incorrectly, I'm not sure. I have a 10K pullup resistor on the base so that current should not flow between collector and emitter. It does. If I move the resistor to pulldown, the LED still lights up.
I'd appreciate a pointer if someone here sees what I'm doing wrong.
Joe
Offline MikeK
Re: Need to be smarter than the transistor
« Reply #1 on: April 13, 2011, 05:15:34 PM »
You've got the pinout correct, but the emitter is the leg with the in-pointing arrow, not the collector.  You've got them switched.
Also, you need a current limiting resistor at the base that you switch to ground.
« Last Edit: April 13, 2011, 05:19:46 PM by MikeK »
« Reply #2 on: April 13, 2011, 06:46:52 PM »
Thanks very much, I didn't understand about the collector and emitter changing places.
Joe
Offline vinniewryan
« Reply #3 on: April 13, 2011, 07:37:29 PM »
http://www.satcure-focus.com/tutor/page4.htm
this is a very good explanation of how they work, and it has a schematic symbol that shows you the correct Base, Emitter, and Collector.
Cheers!
Offline MikeK
« Reply #4 on: April 13, 2011, 08:06:07 PM »
This is another good explanation of transistors: http://www.rason.org/Projects/transwit/transwit.htm
« Reply #5 on: April 14, 2011, 05:37:18 AM »
Thanks guys, appreciate it.
Joe
