Author Topic: Swerve Drive Parts  (Read 3256 times)
Offline KylepowersTopic starter
Swerve Drive Parts
« on: April 20, 2011, 06:56:25 PM »
Im looking for gears and such that will work well with a swerve drive. Dose any one have any suggestions on where to get gears for the motors that will turn the swivel moduels?
Re: Swerve Drive Parts
« Reply #1 on: April 23, 2011, 04:57:40 AM »
Have you considered small pitch timing belts?
« Reply #2 on: April 23, 2011, 09:15:33 AM »
I have been looking at those and the more I look the more I think those are the way to go. But can I get ones only 4 1/2 inches long?
« Reply #3 on: April 23, 2011, 07:57:31 PM »
These are very close, but is the 4½" the distance between pulleys or the entire belt length (if cut and measured)?
You can calculate the exact size you need here and find lots of different lengths here (main page here).
Remember that you nee some way to tension the belt(s), either by a "blind" pulley, or by being able to adjust the position of one of the pulleys.
« Reply #4 on: April 23, 2011, 09:46:30 PM »
that would be from the pullys outer edges away from each other. yes im going to add a tensioner pully to each one but i will need four belts.
« Reply #5 on: April 24, 2011, 09:00:34 AM »
Then you need belts that are more than 9" - when you have settled on the pulley sizes, use the calculator to get the exact length.
