Author Topic: HS-303 and HS-311  (Read 3252 times)
Offline soninja8Topic starter
HS-303 and HS-311
« on: May 21, 2011, 02:00:57 PM »
Ok, so I have two HS-303 servos. They pull a lot of torque, but I need some more speed. Would the HS-311 go faster, and still have enough torue to pull a couple of pounds?
Thanks,
Soninja8
Offline Gertlex
  • Helpful? 24
    • Index of Oddities
Re: HS-303 and HS-311
« Reply #1 on: May 21, 2011, 05:50:54 PM »
I
« Reply #2 on: May 21, 2011, 06:12:40 PM »
Google is  your friend.
http://www.servodatabase.com/servo/hitec/hs-311
http://www.servodatabase.com/servo/hitec/hs-303
(and so is servodatabase, apparently)
I know http://www.servodatabase.com/compare?servos=835,836
I've used servodatabase, but it says they are the same besides hs-311 having less toque. I dont understand this, because the hs-303 is so slow, and all the videos that ive seen of people using the hs-311 is fast...
Any idea?
« Last Edit: May 21, 2011, 06:14:23 PM by soninja8 »
Offline Gertlex
  • Helpful? 24
    • Index of Oddities
« Reply #3 on: May 21, 2011, 07:09:08 PM »
Had never previously heard of the 303.  What voltage are you operating at?
I
« Reply #4 on: May 21, 2011, 07:41:25 PM »
6 volts, the max
    • RazorConcepts
« Reply #5 on: May 23, 2011, 09:30:40 AM »
Any idea?
Since the HS-303 is old and discontinued, the performance may be worse than when it was new.
The HS-311 would be an improvement, but it's just a typical standard servo. Look at servodatabase to find specs of servos that are better.
