Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
Another option is use a brass wheel collar with a set screw sold for retaining model airplane wheels. Then solder a brass disk to the collar. Drill three or more holes around the disk for screws to the wheel like you would do with a servo horn.The brass collars are chrome plated so you need to file off the chrome to expose the brass. Then use a strong solder (not electronic solder) with an acid flux. Stay Bright brand works very well. http://www.google.com/products/catalog?q=stay+bright+solder&hl=en&client=firefox-a&hs=6x3&rls=org.mozilla:en-US:official&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=1280&bih=839&um=1&ie=UTF-8&tbm=shop&cid=293056921266805762&sa=X&ei=YTcJTrjeJoT10gGHi52IAQ&ved=0CFAQ8wIwAA
Hi Corrado33,Can you tell me where you got your red servo horn pictured bolted to a Transwheel (either 2" or 4" OD), the part # ordered and the gear size it mounts to on a servo?Thanks, I'm trying to promote Society of Robots while also promoting solutions for our wheels, Kornylak Transwheels and Omniwheels for robotic applications, and need this info. so I can link back to a source of the servo horns.Thanks, Pete Ward Sr. Project Engineer, Kornylak Corporation
