Beginners: please read this post and this post before posting to the forum.
Ordinary TV provides 24 to 25 FPS and human eye cannot detect any flickering, does it mean that LED flashing at 25Hz would be flicker free as well? Or are these different things?
unless you're modulating the ON pulses of the flashing.
In essence what I want to build is an LED flasher, however it will make LED flash so fast that it will seam like continuous light.
He wants to build an LED flashlight with 2 brightness settings from what I can understand in his second post.
Shouldn't you just... leave the LED on all the time if you want it to seem continuous? The terminology "LED flasher" is rather confusing as well.
No, I want to build LED flashlight with 255 brightness settings Then I'd miss on learning how to program uC, how to create PWM using uC and I wouldn't have flashlight with 255 brightness levels Why LED flasher is a wrong term if PWM flashes LED say 3000 times per second? My first and second post clearly states what I plan to build and my question was answered straight away. What's the point to discuss about irrelevant things such as the name of the topic even though it does make sense; it's not like I named the topic "How to calculate torque of a motor" and then asked a question about PWMing LED.
[...] I want to build LED flashlight with 255 brightness settings
