Author Topic: Camera with roborealm HELP  (Read 2659 times)
Offline ATRmakerTopic starter
« on: July 23, 2011, 01:48:12 AM »
I am looking for a cheap wireless camera to a laptop that can use roborelam ?
IF i use a Pinhole 1.2GHz Wireless A/V NTSC Spy Camera + Receiver Set
http://www.chinavasion.com/product_info.php/pName/pinhole-12ghz-wireless-av-ntsc-spy-camera-receiver-set/
Is it possible to connect to a laptop ? if so how ?  and will it work with roborealm.
Or should i stick with a IP webcam , if so how can connect it to a laptop in an outside environment ? with without any internet connection,
Thanks for any suggestions in advance
Re: Camera with roborealm HELP
« Reply #1 on: July 23, 2011, 09:49:14 AM »
A spy cam will need a digitizer to convert the analog signal. You can get USB digitizers that aren't much larger than about 4 regular thumb drives.
A WiFi IP cam will be easier, if your laptop has got the WiFi built in (most newer laptops do).
How easy/hard it will be to get into RoboRealm, I cannot say though, but I'm sure you can find some info about it, either on their site or via Google.
« Reply #2 on: July 24, 2011, 05:45:20 AM »
Thanks  for your suggestion , If i used the camera with the receiver to think i could use av to usb cable.
