Author Topic: Paddles(flippers) Construction/Installment  (Read 3079 times)
Offline NGuggemosTopic starter
« on: August 04, 2011, 06:33:54 PM »
I need help on how to construct paddles on my robot. Do I attach the to my treads, or what can I do to successfully attach them to my robot? I would also like to know more on how to make them? I would love any type of comment or suggestion for this even if your not quite sure.
Offline Sylvestre
  • Helpful? 13
Re: Paddles(flippers) Construction/Installment
« Reply #1 on: August 04, 2011, 06:56:03 PM »
Something just like this (located in the link below), right?  Your going to have to use two servos to rotate them, but I'm not sure how your going to install motors when the servos.  I've actually been looking for something like this to.  If someone who is knowledgeable with treads could help us, I'd really appreciate it.
http://www.google.com/imgres?q=packbot&um=1&hl=en&sa=N&rlz=1C1RNCC_enUS321US321&biw=1280&bih=709&tbm=isch&tbnid=onpsVUknYRDnGM:&imgrefurl=http://defense-update.com/products/p/pacbot.htm&docid=kfdl-RwEOE_RRM&w=400&h=311&ei=cj87TrejE6qssAK5mNAX&zoom=1&iact=hc&vpx=170&vpy=122&dur=2515&hovh=198&hovw=255&tx=175&ty=134&page=1&tbnh=121&tbnw=155&start=0&ndsp=26&ved=1t:429,r:0,s:0
« Last Edit: August 04, 2011, 07:05:32 PM by Sylvestre »
« Reply #2 on: August 05, 2011, 08:11:34 AM »
Thank you very much Sylvestre. I really need more info. on what Sylvestre was suggesting.
« Reply #3 on: August 05, 2011, 08:19:48 AM »
In case you don't know what the purpose of paddles is... They are used to flip your robot on the correct side if your robot flips over on its back.
« Reply #4 on: August 05, 2011, 08:22:15 AM »
If you want to know what they look like... Click on the link that Sylvestre sent me(second comment) and you will see how the paddles are constructed on the robot with treads.
Offline intexmo
« Reply #5 on: August 16, 2011, 10:44:17 AM »
I also need help to make this type of flipper
can you plzzzzz help me
I have taken a shaft and connected both the flippers with it
i also have 12v dc 10kg/cm torque motor 60 rpm i have connected it to the shaft through gears,but still i m not able to flip my robot
plzzz help me
« Last Edit: August 16, 2011, 10:47:08 AM by intexmo »
