Squirrels have fuzzy tails.
The connectors on these switches are either 3.5 mm stereo or mono connectors. I would like to know if there is a microcontroller with a 3.5 mm output to which I could interface with the wheelchair control box.
In addition, this same microcontroller would also need to interface with a PC through a USB connection, but that's sort of a later stage on this project.
Thanks everyone for your helpful advice. I don't know much about electronics so I may be trying to go about this the wrong way. I just want the simplest and easiest solution. I would prefer not to do any soldering or any other DIY work, since this needs to be extremely reliable and safe. My preference is to simply use an off-the-shelf product where I can just plug everything in.
If I could go straight from an output on my PC to the control box on my chair that would probably be the best solution. Could I really use the audio output?
I did say I was using a stereo connector, but really I should go with a mono. Stereo does work, but the input jack on the control box is mono. Not sure if this makes a difference or not. I just want to be on the safe side.
Basically what I'm wanting to replace is a very simple mechanical switch with a mono plug on one end. Here's an example of what I'm talking about:http://www.enablemart.com/Catalog/Sensitive-Switches/Micro-Light-Switch
Since I posted my prior message, I discovered a device which might do what I am needing.http://www.cleware.net/produkte/p-usbswitch35-E.htmlWould this work? I am in the US and so I would like to find a product made here that can do what that device does, assuming it is the correct device for my needs.
Please note:PC programs may fail or may be interfeared through other programs. Don't connect devices to the USB-Switch 3,5" that may cause harm if the switch turns on unexpected!The usage of the USB-Switch 3,5" is strictly prohibited when the failure of the sensor will harm people.
