Author Topic: Is My Schematic Done Correctly?  (Read 2390 times)
Offline SylvestreTopic starter
  • Helpful? 13
« on: August 26, 2011, 01:58:44 PM »
Hey everybody,
I posted this to see if you guys could double check my circuit and make sure I haven't done anything incorrectly.  Yes I know my drawing skills aren't the greatest and I could have done it in Eagle, but I prefer hand drawing my schematics.  Attached first is the schematic of the circuit.  Attached second is current and and voltage requirements for each device and then there is a few additional notes.
The motors are two 24 volt 350 watt motors.
Where it got cut off on top it says camera and where it got cut off on the bottom it just says the specs of the battery and how it is connected in series to make the power supply 24 volt 75 AH.
Your guys help is greatly appreciated
« Last Edit: August 26, 2011, 07:09:24 PM by Sylvestre »
Offline Daanii
Re: Is My Schematic Done Correctly?
« Reply #1 on: August 27, 2011, 09:37:43 AM »
[deleted]
« Last Edit: August 27, 2011, 11:38:45 AM by Daanii »
Offline Afroman
    • Oscilloscope tutorial video
« Reply #2 on: August 28, 2011, 06:26:23 PM »
It looks like you are putting caps in series with the motors?
  • Helpful? 13
« Reply #3 on: August 28, 2011, 07:49:22 PM »
They are supposed to be connected to the motors' terminals to reduce electrical noise, but it turns out the terminals on my motors are in the casing of the motor so I will need an alternative route to reducing electrical noise.  Any suggestions?  Can I connect them on the wires as close to the terminals as possible and then connect them to the case of the motor? (I will be using two capacitors for each motor)
 I am using these motors
http://www.monsterscooterparts.com/24v-350w-motor-11-tooth-25-chain-my1016.html
« Last Edit: September 02, 2011, 09:11:53 AM by Sylvestre »
