Author Topic: Question about PWM frequency  (Read 2284 times)
Offline joe61Topic starter
« on: September 18, 2011, 09:43:56 AM »
I'm reading this Application Note from Atmel, which has the following statement:
"The output filter smoothens (sic) the output signal and removes the high-frequency PWM carrier signal"
I don't understand this. What is the carrier signal that's being removed? I thought the carrier was simply the period between two successive duty cycles. How would that get removed?
Joe
Offline mstacho
  • Helpful? 10
Re: Question about PWM frequency
« Reply #1 on: September 18, 2011, 10:52:13 AM »
from what I could tell all they're saying here is that it reproduces the audio signal, not the ON-OFF signal of the PWM.  In other words, they said in words what you understood intuitively -- that when you pass PWM through a filter, you get an approximation to the original analog signal back out.
In all honesty I have no idea why they even bothered to put that in.  It's the short form version of why PWM works :-P
MIKE
« Reply #2 on: September 18, 2011, 11:56:17 AM »
Sorry if I'm being dense, but what is the on/off signal? For example, if the duty cycle is 0, what signal would be there?
Joe
« Reply #3 on: September 18, 2011, 12:00:49 PM »
It's the PWM sample frequency that's being removed (like in any form of digital audio).
Proper digital audio use a PWM frequency of at least 300kHz, to represent 0..20kHz faithfully.
I have to disagree a bit with the datasheet though, as a steep cut off of anything above 3kHz (which a 6kHz sample frequency will do) is a bit low and while there are language differences, it won't work well for Danish (and will probably be a challenge in most languages).
I have done a wee bit of research in how low pass filtering of voice elements will change them into sounding like other sounds and the only reason that a 3kHz wall might work is because we use context and other clues to guess the words.
For a more understandable speech, you need to keep at least up to 6kHz (and for precision, count on 8..16kHz).
