Author Topic: need equivalent for L239d.  (Read 4400 times)
Offline kevinkollinmathewTopic starter
« on: October 02, 2011, 02:29:23 AM »
please help me to choose an equivalent ic for L239D.i wanna to controll a wiper-motor,which requires high torque,and high speed too...so needs high current output..please help me.
« Last Edit: October 02, 2011, 02:31:06 AM by kevinkollinmathew »
Offline billhowl
  • Helpful? 32
Re: need equivalent for L239d.
« Reply #1 on: October 02, 2011, 07:56:44 AM »
.. wiper-motor,which requires high torque,and high speed too...so needs high current output..please help me.
How high the current? 2A? 10A? 25A?
Motor Drivers from Pololu
http://www.pololu.com/catalog/category/11
For some of the wiper-motor, the minimum required current for the motor is 1.6 amps at 70 rpm, 0.9 amps at 41 rpm and 4 amps if you elect to run it at 106 rpm, the motor start current will close to 5 amps, the motor will draw close to 14 amps in a stalled condition. So you must test your motor for the stalled current to select correct motor driver.
« Reply #2 on: October 02, 2011, 08:13:52 AM »
im a fresher to this topic,,so will u please say the power requirements,and current requirements of a wiper motor inorder to push another bot of 10 kgs...ma bot's also of 10 kgs.how can i calculate that?
« Reply #3 on: October 02, 2011, 08:17:59 AM »
wats d rating of a l239d??plz hlp
Offline billhowl
  • Helpful? 32
« Reply #4 on: October 02, 2011, 08:49:18 AM »
L293D
600mA OUTPUT CURRENT CAPABILITY PER CHANNEL
1.2A PEAK OUTPUT CURRENT (non repetitive) PER CHANNEL
« Reply #5 on: October 02, 2011, 09:12:01 AM »
if my robot's wired and im using wiper motor..and my bot's 4 tyres and 3 hammers,out of 3,,2 perform to and fro motion and 1 perform up and down motion..how many motors does i need,if ma objective 's to push a bot weighing 10 kg,,and my bot's also 10 kg..how can i control my motor movements???plz help.
Offline joe61
« Reply #6 on: October 02, 2011, 11:12:27 AM »
I think one of the reasons you're not getting a lot of answers is that your questions are very vague, and involve too many variables. To answer some of these almost involves doing your design for you. The way you ask a question can have a lot of influence on the number and type of responses you get.
Try a more systematic approach. For example instead of asking a bunch of questions all at once, each of which is too vague to answer, take one particular piece of the problem. Give a description of what exactly you want it to do, and what facts you know about it. Most importantly, describe it in clear language that will convey the problem to people who are not you and don't have your view of the situation.
Often, simply writing down such a description makes the problem more clear, and the answer easier to get to.
Hope that helps
« Reply #7 on: October 02, 2011, 11:16:30 AM »
thnx fr ur feed back
Offline bobthefirst1
« Reply #8 on: October 03, 2011, 05:29:30 PM »
may be very dumb reply but why do you need an equivalent and just not use the L239d?
