Author Topic: battery  (Read 2281 times)
Offline banabotTopic starter
battery
« on: October 15, 2011, 07:55:03 AM »
My problem is that when I start the motor, the battery is shorted for a moment, this is because the maximum current pick is over
How can I solve this problem?
« Last Edit: October 17, 2011, 01:16:53 PM by banabot »
Re: battery
« Reply #1 on: October 15, 2011, 08:25:02 AM »
What battery? Link to data sheet.
What is the battery voltage?
Is there a voltage regulator between the battery and the PIC?
Are there caps connected close to the PIC?
How are these wired?
It is common to get a voltage drop on the wires and the battery when a heavy load is applied. It helps to run separate wires from the battery to the motor driver (of heavy gauge) and to the PIC. This way any voltage drop on the wire due to the high current draw from the motor (V = I*R) is not 'seen' on the wires to the PIC.
Re: battery
« Reply #2 on: October 15, 2011, 08:38:38 AM »
...And what's between the PIC pin and the motor?
You didn't connect the motor directly to the pin?
Offline happy_hippo
    • Read Stuff Here
Re: battery
« Reply #3 on: October 24, 2011, 05:30:57 AM »
Add some capacitors in parallel. As written in some tutorial on the society's website. (Make sure you check the polarity, or they will explode , haha : mine did a few days ago :D )
??? -> :D
