Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
My first model just used my fingers [...] but its rather weak and I'm ready to move to the next phase of the project. Motorized gripper.
Are my assumptions correct, or am I missing a some fundamental concept?
Any help or input would be greatly appreciated, as this project could look really good on my resume (looking for a career in prosthetics after I finish college).
And I appreciate the advice about cutting the current when its gripping. I'm not familiar with the hardware that would be able to do that and I was hoping to keep this limited to just a power source, motor driver, motor and switches to work the mechanism. Would adding that feature take much more then that?
Also, I really like the idea of integrating a force senor (I was surprised at how cheap they are!) but I feel I would need a mircocontroller to make that work right, so that will probably have to wait until the MkIII hand.
I was planning on using an L293D chip. Probably just with the 'Secret' Motor Driver kit from solarbiotics [...]I only need to drive one motor at the moment, so I don't mind that it links the 2nd set of inputs/outputs to the first set. Its cheap, and if need be I can solder the parts on a bigger board to include, say, a transistor.
I've been trying to look into how to use a transistor to add over current protection, but most of what I've been finding has been using them as switches or how to protect THEM from over current. Would you mind giving me a reference where I can read up on this, or walk me through how to wire it up to the chip?
[...] fuses or circuit breakers to protect the motors. I'm assuming that isn't the type of solution you were talking about.
How would an over current circuit function?
I assume that at a given current level it shunts some of the power someplace else but I have no idea how that would be accomplished.
If you would be so kind, I would really appreciate it if you could draw up the circuit with a DPDT switch and the over current protection.
I'm looking for a high torque motor, preferably with a worm gear so it will self lock and I don't have to worry about stalling the motor, but the only worm gearbox I found was plastic and I question its durability. So I decided I'd just go with a motor that's already torque-y and deal with a rack and pinion setup.
Sweet! I just have a question about F1, by the positive battery terminal. Is that a 1.5db attenuator or a 1.5 amp fuse? I've never seen the designation 'AT' before (again, I'm pretty inexperienced with circuitry).
Thank you so much for all of your help! I really appreciate you putting up with all of my n00b questions and getting me set on the right track.
